I am trying to build a flasher unit that is powered from 9-30V.
The lanterns are also powered from the same 9-30V and are turned on by an enable signal that must be 11V+.
I have opted to use a 12V buck boost converter to provide a steady 12V to drive the enable output.
I have also added an alternative circuit using a 5V LDO which then powers a 12V boost converter (not sure if this is a normal way of doing things).
I have been looking at ways to drive the enable pin with MOSFETS and optocouplers and all the circuits I see have resistors involved on the outputs so when I add the load (the lantern) it drops the voltage below 11V and the lantern will no longer turn on.
I am using a 555 timer that has a frequency range between 0.5 and 2Hz.
The circuit must also drive two lanterns alternatively.
I had a few ideas on how to drive the enable pin but not sure which one to go for and if they are best practices.
1) Power the 555 timer from 12V and drive the lantern enable pin directly from the timer and use a P channel MOSFETas an analog switch to invert the signal and driver the alternate lantern.
2) Power the 555 timer from 5V and use an optocoupler that switched 12V. I have built a circuit this way and it works but I am unsure of its best design practice as the collector is tied to 12V and the emitter is going directly to the output? if I add a pull up resistor and the enable output to the collector and tie the emitter to ground then the lantern loads the output and drops the voltage below 11V.
Any other thoughts or recommendations on best way to do this would be amazing.
I have attached my schematic to this thread.
Thanks
Thanks
