doubts regarding clock frequency of 18f4550
embpic
Joined May 29, 2013
189
i have doubt regarding oscillator frequency.
i am using 18f4550, XC8 compiler, primary oscillator of 20MHz. i have kept following configuration
Rich (BB code):
// CONFIG1L
#pragma config PLLDIV = 5       // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 2       // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes from the 96 MHz PLL divided by 2)
// CONFIG1H
#pragma config FOSC = HSPLL_HS  // Oscillator Selection bits (HS oscillator, PLL enabled (HSPLL))
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
#pragma config IESO = ON        // Internal/External Oscillator Switchover bit (Oscillator Switchover mode enabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = SOFT       // Brown-out Reset Enable bits (Brown-out Reset enabled and controlled by software (SBOREN is enabled))
#pragma config BORV = 2         // Brown-out Reset Voltage bits ()
#pragma config VREGEN = ON      // USB Voltage Regulator Enable bit (USB voltage regulator enabled)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config DEBUG = 1
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config ICPRT = OFF      // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
so i am using oscillator mode as HSPLL for USB, and PLLDIV is 5 for derive 4MHZ frequency for PLL input for deriving 48 MHz clock.
I have confusion in system clock.
is following bits decide of system clock??
11 = 96 MHz PLL divided by 6 to derive system clock
10 = 96 MHz PLL divided by 4 to derive system clock
01 = 96 MHz PLL divided by 3 to derive system clock
00 = 96 MHz PLL divided by 2 to derive system clock
if yes then what is time for Machine cycle?
how to check frequency on which pic is running using pickit3 ??
THE_RB
Joined Feb 11, 2008
5,438
A good method to find out what clock frequency the PIC is running at is to set TMR0 to 1:1 prescaler, and use this very simple code;
Rich (BB code):
TRISB = 0x00;  // portb is outputs
while(1)
  if(TMR0L >= 128)  LATB = 0xFF;
  else              LATB = 0x00;
What that does is to output a frequency on the PORTB pins where the frequency is the instruction speed /256.
So if your clock speed is 48 MHz, inst speed is 12 MHz, and the freq output is 12MHz/256 = 46875 Hz.
ericgibbs
Joined Jan 29, 2010
18,879
Look at this marked up clip from the datasheet.
The Basic CPU clock [refer image] is further divided internally to produce 4 machine timing periods.
So a 20MHz Xtal divided by 2 would give give a CPU clock of 10Mhz, this is always divided internally by 4, so an Instruction cycle would be 400nSec
To double check, use Roman's method.
E
