- Joined Jan 23, 2018
- 18,590
Now I am wondering about how you would couple a rotary hammer drill motor to a 3/4 inch steel pipe. I own three rotary hammer drills, two of them have standard drill chucks, with a half inch maximum drill diameter capacity. The third one is used with drill bits having a male spline extension and is intended for larger drill bits, up to about 4 inches. Those are quite expensive, by the way. The mass of the internal hammer part is more than the mass of the smaller drill bits, and so the drills are very effective transferring the impact when I use a smaller drill bit. But the mass oof a section of steel pipe is much greater than the mass of the internal hammer and so it does not seem that the energy transfer will be much. You may do better with a drive cap on the pipe and a big hammer to drive it with. You can rotate the pipe with any of a number of kinds of wrenches as you hammer it. I have used this method to install steel fence posts in hard gravel and it does work. But I did need to pull the pipe out frequently to clear it. The ground was solid enough that the hole did not collapse when I pulled the pipe out. But I am not sure how that wil work with a pipe several meters long.
