Likely just a visual processing artifact from video system level overloading (contrast/brightness).It looks like you are looking at the pad with no solder on it.
Looks like stress fractures in the solder mask, probably do to differential thermal expansion during the thermal testing -- corners tend to concentrate stress.Has anyone seen this before? See the white lines jetting out from the corners of the pads. This board underwent automotive thermal stress testing and is still functional, but I have never seen cracks like these before.
Thank you WBahn. We normally run large numbers of samples, and if I understood the engineer correctly, this was the only one that creaked like this. Do you think it has anything to do with supplier quality, or is it more likely that the material is of low quality?Looks like stress fractures in the solder mask, probably do to differential thermal expansion during the thermal testing -- corners tend to concentrate stress.
Shouldn't impact functionality and I doubt it would have a significant impact on life expectancy, but they could grow over time and possibly result in pieces of soldermask flaking off or provide a path for moisture to get in underneath it. My guess, though, is that they are benign. But automotive qualification my still have issues with them.
I have no idea, especially based on one picture -- and if explaining/understanding this is important, I wouldn't recommend asking strangers on the Internet, either. There are lots of labs out there that are dedicated to doing fault analysis and investigation, so I would recommend finding one that specializes in PCB quality assurance and engaging them for their professional evaluation. They may offer a fairly low cost preliminary evaluation based on visual examination of the board, detailing potential causes and likely ramifications. They can probably give you some idea of the likelihood that this is indicative of something potentially larger, versus as more-or-less one-off occurrence. They can also give you an estimate of what it would take and cost to pursue a more definitive explanation of the cause.Thank you WBahn. We normally run large numbers of samples, and if I understood the engineer correctly, this was the only one that creaked like this. Do you think it has anything to do with supplier quality, or is it more likely that the material is of low quality?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
