Adding the 0.1uF caps across each IC has caused it not to work.
There's the occasional flicker of a digit when you either connect
or disconnect the power supply, but the rest of the time, at least the display is off.
In the diagram on the website, the 4050 ICs are powered by 12 Volts.
Is this correct? I don't see any other way to power the displays.
The displays are common cathode, not common anode.
