Great. I wouldn't worry too much about unplugging the cables for the photos.
What I want to know is are the ICs socketed?
Where are those components labelled FL? These are the inductors supplying power?
We need to probe both ends of each FL.
Wise idea to build a temporary shelf for the scope. As you say, it is better to be facing the scope while probing.
For photos, use a tripod. It would be better to use manual focus if you have it on your camera. Flash should be ok. If not, make sure you have bright lights.
Good luck. Take your time.
