I'm having success with C18, C20, C55 & other capacitors that are in series, but having problems with readings, like the resistors, when they are in parallel with other components, but the main things seem OK.....I'm wondering if I'm just going too deep and would have to unsolder capacitors to check them.........it may be time to just put my TR8 & TR10 back on the board, check for obvious shorts, then try to power it up and see if the fuse holds....if it does we can get into voltages and current for further checks if needed...Hello Ron,
Succes and see you later,
Bertus
Repairmen deserve, make their pay, and provide a valuable service.So it's not fixed yet??
How many hours so far? And people wonder why it can cost $200+ to repair a power amp...
Current status: No, it's not fixed right now...preamp is confirmed to be working to FX out, with TR8 & TR10 removed, not blowing fuses...haven't found any other bad components yet......I'll surely listen if you have something to add.....hoping to learn also if you have any tricks up your sleeve.(you may want to read the whole thread to get the complete picture of what's transpired)...Thanks.... The other great thing here is meeting people from all over the world...islands in the Indian Ocean, now that's a new contact.....Great!!So is it fixed or not.
I did not go thru all the replies, but read the first post.
If not fixed, if you are up to it, then I can help to get it up and running.
I'm sorry I missed this thread
PS. Did you know there is a way to power amps without (blowing fuse) or destroying any other component even if the out put stage has a shorted component
Rifaa
I'm thinking that might be overkill at this stage to remove capacitors as there's not much room to work with this still hooked back up to the power supply, and I've already taken that out a while back and not wanting to go that far back unless necessary. I'd like to think more on the lines of installing TR8 & TR10 and do some resistance measurements and calcs, check for potential shorts, and if it looks good I could power up and see if it holds, recheck voltages and current.Hello Ron,
Thanks for the credits.
As for the capacitors, it is best to take them out for the check.
Inside a circuit there can be components that disturbe the measurement.
Be sure they are discharged before measurement.
Some meters will not like capacitors with some charge in it.
For the electrolitic capacitors, they can have tollerances upto 20 %.
So the 100 μF can measure anyting between 80 and 120 μF and still be good.
Greetings,
Bertus
Thank You...I'll take special cautions there to check all these points before and after installing TR8 & TR10, and before any power is applied.Hello Ron,
When checking the transistors, take special care of TR4 and TR7.
(when both are defective TR9 will probably aslso be defective)
Of course TR7 acts on TR8 and TR4 acts on TR10.
When those have a short in Collector-Emittor, full current will be send into the endstage.
This should have the current limiting transistors TR11 and TR12 activated.
Greetings,
Bertus
thanks....no visible problems...Ron,
Just to see if any of the caps are bad, try and look for any "bulging" caps visible. Usually the electrolytic or tantalum caps have a flat surface on top but if they go bad sometimes they can bulge outward. Note that I didn't say bulging as in width, but just at the top of the caps.
This might make a lot sense in that a power surge, etc...... may have shorted the internal diodes across C-E in the 2 major power transistors TR8 & TR10(BDV's), which is the protection that may have saved the rest of my components.Hello Ron,
You are correct about the BDV's.
When you look at the datasheet of mospec, they show some extra resistors accross the B-E connection and a protection diode accross the C-E connection.
(see datasheet).
Usualy I search for datasheets at ICMaster.
They have datasheets from several suppliers.(other do not show the diode on the BDV's).
http://www.icmaster.com/
As for TR9 there are rather low resistors accross it, making the reading odd.
Greetings,
Bertus
Please comment on my last question regarding TR9, R73, R74...?Hello Ron,
The protection diodes are of use when driving inductive loads.
This can be motors or relays.(the transistors are also uses for driving them).
The diodes protect the transistors against back emf of the inductive loads.
Greetings,
Bertus
