I am working on designing a helical antenna and have been using the book Antennas for all Applications as my primary source of information. In the book, Dr. Kraus describes a method of converting the ~150 ohm impedance of the antenna to 50 ohms at the coaxial cable interface. This is done by gradually flattening the antenna's copper tube as it approaches the ground plane, then precisely spacing the flattened end of the tube from the ground plane with a dielectric. The coaxial feed line is inserted through a hole in this dielectric and soldered to the end of the flattened tube.
That sounded easy enough to do, but I have run into a roadblock. In the book, Dr. Kraus provides the following formula for calculating the thickness of the dielectric needed:
where h is the thickness of the dielectric, w is the width of the flattened tubing, ε_r is the relative permittivity of the dielectric sheet, and Z_0 is the characteristic impedance of the dielectric sheet.
I cannot figure out how to calculate the characteristic impedance of the dielectric sheet. I have only basic knowledge on this subject, and I am only really familiar with what impedance is and why impedance matching is important in antenna designs. Beyond that, though, I really have no clue what I'm doing. If it helps, here are the values I am using for the other variables:
w = 8.1966 mm
ε_r = 2.1
While my ultimate goal is getting the correct characteristic impedance so I can proceed with my design, I would also like to learn the proper way of calculating it in the first place. I would greatly appreciate any explanations as to how this is done!
w = 8.1966 mm
ε_r = 2.1
