Wow I am on a role today!There ain't no positive on a transformer. All transformers are AC.
Sheesh....So it wouldn't matter how I wire it up then I suppose. (The two wires on the secondary).
Please exuse me. I'm acting terribly dumb.
So then there is a positive on transformers?There ain't no positive on a transformer. All transformers are AC.
Haha. Very funny.Stereo?
John
Ritesh: That is neither a correct nor safe assumption. Where did you get that idea?Measure resistance with multimeter low resistance is Primary.
Nah...Transformers may indeed have "polarity". There are some rules that apply to winding interconnections - if you break them, you may break your transformer as well.Are you trying to figure which is the primary vs. secondary?
There is no polarity in a transformer, not hot, nor ground.
A transformer is an AC device, and it isolates the two sides, and is not connected to the core.
Simple, for step down transformer primary resistance is more compared to secondary.Ritesh: That is neither a correct nor safe assumption. Where did you get that idea?
John
Still, bad assumption. You don't know if a transformer is a step down or not, without markings who can tell? Transformers are also reversible, which is handy for an inverter. I love it when the manufacturer puts the specs on the case of the transformer. This used to be the standard.Simple, for step down transformer primary resistance is more compared to secondary.
That is just plain dumb to do. Why did YOU do it?It depend on rating of it, as if we connect step down transformer reverse to high supply line (i.e. 220V) i seen it blast with good sound.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
