Your image link did not work.
Please attach the image to your post using the "Go Advanced" and "Manage Attachments" buttons below the reply box. .PNG format images are preferred.
You want a low-pass filter with a sharp cutoff below 60Hz.
If you want it to be usable on 50Hz systems, then you need an even lower cutoff frequency.
A Chebyshev filter will provide a brick-wall-like response, if you allow for significant ripple in the passband; perhaps 2dB-3dB.
Here is a 5-pole Chebyshev-type filter whos' values were rounded to the nearest 5% tolerance:
A plot of transmission is attached.
