Hello can you help me plase
Basic and I needed to design a digital clock
What kind of digital clock do you want? One made from discrete logic gates or one using MCU? How many digits do you need? Output go to LED or LCD?همسات;733253 said:Hello can you help me plase
........Why?همسات;733253 said:Hello can you help me please
Does that include candle clocks, water clocks, and sundials?And - There is a quantity of time that can not be sub-divided. Physical reality has a lower limit on a tick. Because of the quantum nature of existence, all clocks are digital.
IMHO,Does that include candle clocks, water clocks, and sundials?
if you use ur finger as a sundial does that make it digital?IMHO,
Candle clocks -> digital
Water clocks -> digital
Sundial -> analog
The first two are based on the molecular behavior of their respective substances and thus discrete/digital events. Unless one were to argue the particle theory of light, I see a sundial as an analog device.
Don't worry he's got all the time in the world.Four days later and no response from a one time poster. I'm beginning to doubt this will end up as a clock.
Interesting point. A pendulum is sinusoidal, or at least non-discontinuous oscillators, but the escapement is a comparator.Depends a bit on what you take analog to mean. Taken as a continuously varying signal, i.e. non-quantized then all spring and pendulum driven mechanical clocks are digital because they use an escapement to regulate the motion, hence the ticking.
