Thanks man for such an elaborative calculation...Basically I got the calculations...
but here agains comes your OMG moment..
As the voltage amplitude Vin is constant there must be some voltage drop across R1 (assuming that R1 is not infinity)..and some voltage drop across C1....
Now in the second case lets suppose frequency changes, but still the Vin amplitude is same....hence same voltage drop is at R1...BUT..now here comes my devil....as with change with frequency, Xc changes and voltage across C1 will change...now here what KVL says is that Vin+Vr1+VC1=0..now if any one of the three changes the other two would have to change in order to make their sum total zero....but with frequency change VC1 changes which in order to satisfy KVL should change VR1...but then I think why should VR1 change since Vin is constant...
so its just like that....with the change in frequency C1 is telling VR1 to change...but on the other hand Vin is telling VR1 not to change as Vin is constant amplitude wise...Its just a tug of war.....isn't..
