How about this ?Hey, based on the picture, what does it means by creating a baseband signal ?
I dont get it. I understand that baseband filter is a filter that will not filter a specific range of frequency.
What does this means ?
Actually, what is the effect of the RC value to the demodulated signal waveform in terms of charging and discharging ?The function of a low pass filter is to pass low frequencies and attenuate frequencies above the filter's corner frequency.
In this case the LP filter is used to attenuate the RF frequency but pass the modulation frequency.
Note that a standard op amp will not work very well as a filter here because of the op amps limited frequency response. An active filter requires the op amp to have significant gain at the RF frequency and a standard op amp doesn't. Better to use just a passive RC LP filter.
Hey yea, so do you means that if I choose a RC value whic give me a cut off frequency below 100 Hz, then I wont get the demodulated signal ?The box acts as a low-pass filter to by-pass the high frequency RF from the rectified modulated signal. It's operation is as follows:
The capacitor is charged to near the peak of the RF sine-wave through the diode. For the rest of the RF cycle (when it's below its positive peak) the capacitor slightly discharges through R1 until it's recharged at the next cycle peak. The RC time-constant is chosen so that the decay time is fast enough to follow the fastest change in the RF peaks due to the highest modulation frequency but slow enough so the RF ripple is suppressed. Typically the RC time-constant would be chosen so that the corner frequency of the filter [1 / (2\(\pi\)RC)] is at or slightly above the highest modulation frequency. (For example the circuit you show has a corner frequency of 159Hz so any modulation frequency above that would be filtered.)
What is fc and W ? fc = cut off frequency ?Hello,
Have a look at page 5 and 6 of the following PDF:
http://educypedia.karadimov.info/library/tut331_04am_dem.pdf
Bertus
2∏f, so what is the f ?I'm not wildly impressed by the linked PDF--It leaves a fair bit of important stuff out.
The "W" is because the original printer could not produce the symbol "ω".which in turn means "2∏f".
Unfortunately,that is probably not something you have learned at this point.
Frequency in Hertz.2∏f, so what is the f ?
The signal.Frequency of which thing ?
Well,actually,after looking at the PDF again,I was wrong!(see P4)2∏f, so what is the f ?
prove it, post some screenshots and interpretation.I do simulate it...refer to my previous post ya..
Thanks )
It is in my previous post.prove it, post some screenshots and interpretation.
by Jeff Child
by Jake Hertz
by Duane Benson
by Jake Hertz
