Hi all,
does anyone have a description of a DLL in layman's terms? I understand that it is similar to a PLL, which locks the frequency and phase of the VCO to the reference signal by comparing the freq/phase of the VCO with the freq/phase of the reference signal.
From what i have understood, the DLL compares the input reference signal with the delayed version of the input reference signal. Is this delay controlled by the (voltage) output of the phase detector?
I guess this is where i become sort of confused. if the loop is not locked until the error is zero (or constant), when we lock, wouldnt the reference signal and the output signal be the same? what's the point of doing that? I suppose in the PLL, you can add a multiplier/divider in the feedback to synthesize other frequencies, but i can't quite wrap my head around the DLL functionality.
i guess that brings me to the final question, can we use the DLL to get rid of a phase difference between two signals? i.e. if i had a ac signal pass through an inductor, could i delay the voltage signal such that the current and voltage are in phase again?
Thanks in advance.
Thanks in advance.
