Yes, you can use a quad. You only have to use one of the opamps on the chip.
If you look on the LM324 datasheet, it will show you which pins hook to each opamp in the package.
be sure to connect all unused pins to ground.
its basically a tone controll.Is this a color organ or a tone control?
G | Need advice on decibel meter | Test & Measurement | 8 | |
B | Decibel Power/Voltage Conversion | Homework Help | 2 | |
S | Decibel sensor sources? | Sensor Design & Implementation | 3 | |
B | Decibel Gain & Linear Gain | Homework Help | 2 | |
B | decibel levels of sound waves | Programming & Languages | 2 |
by Don Wilcher
