you seem to be, and I appologise if I'm wrong, that a high current alternator in a car iputs out that level of current ALL of the time. But that's not how it works. If they, say in your case, put out 140A at all times they would ruin a battery in no time flat, and that just doesn't happen in real life. The regulator only allows the alternator to put out what is needed by the load. A vehcle, sail boat or car, olny recharges the battery after the starting and then all of the output goes to the running of the vehicle, lights, radio, ignition what ever.From everything I've read so far it sounds to me that my main problem is the voltage regulator inside the alternator. To address this I am learning now how to either remove the one thats built in or buy one without one built in.
You have a BMS on your Lipo you said. If you were using a BMS connected to the mains for charging, would you be concerned by the available mains current? I should hope not. The BMS is there to monitor and regulate the battery charge, that is it's job, just let it do it.
