I have this waeco fridge for my camper van, equipped with a BD35F compressor.
When the fridge is plugged on 230 V, it works perfectly
When it's plugged on the battery, it does not run properly. It starts running, The voltage of the battery drops to 11,6 V in 2 to 3 seconds, and then the compressor stops working, the fan takes over... and then the same cycle repeats every 1 or 2 minutes.
This is not enough to keep the fridge cool.
The battery is less than 1 year old, barely used. It's a Deep Cycle AGM DUAL FDC 12-115, working at 118 Ah.
Do you know why the voltage of the battery drops when the compressor starts ?
Do you know why the compressor stops working at 11.6 V whereas the safety cut off voltage, according to its manual, is 10,4 V ?
The manual of the compressor says it works with a maximum current of 5 Amp (maybe 6 if it's cold, which it's not), and my battery is 118Amp.h... This should be more than enough, what do I miss ?
I barely know anything about electricity and electronics, so I may miss obvious things, so do not hesitate to explain my mistakes.
I have checked all the connexions, everything is well plugged where it's supposed to be.
The only thing I haven't checked yet is the wire diameters.
Thanks a lot
Thanks a lot
