So for my engineering project, I have to increase the number of inputs by using 2 74HC165N. Is it possible to daisy chain the two together so that why I don't have to read only one serial pin rather than reading 2 of them?
It probably works for SIPO. What makes you think it won't work for PISO?Doesn't that work for serial in parallel out shift register? This is a parallel in serial out register.
It says so in the datasheet. Also, is it easier to connect QH of one register to one input of the other register since I'll most likely have them running on the same clock signal?It probably works for SIPO. What makes you think it won't work for PISO?
