bountyhunter
- Joined Sep 7, 2009
- 2,512
I am saying that the heat sink specs for natural convection assume no airflow. Period. Obviously the air does not sit dead still, there is some movement but there is no forced airflow. Convection effect on a heatsink sitting on top of a PCB is basically useless since the board blocks vertical airflow. Even if you get the board oriented vertically and have an air path, convection on small SMD heatsinks is pretty useless because they are close to the PCB surface and there are other components about the same height blocking the air flow so it basically "ski jumps" across the top of the components greatly reducing effect. You also have other power devices "pre heating" the air in the vicinity which raises the ambient temperature the heatsink is surrounded by. SMD heatsinks generally perform a lot worse than expected due to these effects.So you are saying natural convection cooling and still air cooling are the same thing?
