q <=1'b0;
q_bar <=1'b1
what does it mean
q <=1'b0;
q_bar <=1'b1
module d_ff( q, q_bar,d, clk);
input d ,clk;
output q,q_bar;
reg q,q_bar; // make q and q_bar register types
always@ (posedge clk) // do the following when the positive edge of 'clk' comes.
begin
q <= d; // assign(non-blocking) d to q on the positive edge of the clock(clk)
q_bar <= !d; //assign(non-blocking) inverse of d to q on the positive edge of the clock(clk)
//Note: these assignments happen concurrently at the positive edge of the clock.
end
endmodule
This assigns a 0 to the output signal 'q'.Rich (BB code):q <=1'b0;
This assigns a 1 to the output signal 'q_bar '.Rich (BB code):q_bar <=1'b1
Now, If you place that into an always block with the sensitivity list being the posedge od a clock, then these assignments will take place at the positive edge of the clock.
Here are some comments to help out a little in your understanding
Rich (BB code):module d_ff( q, q_bar,d, clk); input d ,clk; output q,q_bar; reg q,q_bar; // make q and q_bar register types always@ (posedge clk) // do the following when the positive edge of 'clk' comes. begin q <= d; // assign(non-blocking) d to q on the positive edge of the clock(clk) q_bar <= !d; //assign(non-blocking) inverse of d to q on the positive edge of the clock(clk) //Note: these assignments happen concurrently at the positive edge of the clock. end endmodule
Your table is repeating itself, but yes, this is the correct functionality.ok thanks for replay
D flip flop function table
d clk q q_bar
0 ↑ 0 1
1 ↑ 1 0
0 ↑ 0 1
1 ↑ 1 0
now I want to write assign statement for this table
q <= 1b'0
Q_bar <= 1'b1
q <= 1b'1
q_bar <= 1b'0
q <= 1b'0
Q_bar <= 1'b1
is it correct ?
No. Remember, q is dependent on what d was before the clock edge. This means d must influence what q becomes, with q_bar simply being !q.Is it true for d flip flop with positive edge
Rich (BB code):module d_ff( q, q_bar,d, clk); input d ,clk; output q,q_bar; reg q,q_bar; always@ (posedge clk) begin q <= 1b'0 Q_bar <= 1'b1 q <= 1b'1 q_bar <= 1b'0 end endmodule
Yes, this is more like it.D flip flop truth table positive edge
d clk q q_bar
0 ↑ 0 1
1 ↑ 1 0
This its what a flip-flop does.I have doubt that one flip flop store only bit 0 or 1
Note that the D flip-flop is referred to as the "delay" flip flop, meaning the output will be the input delayed by one clock cycle. Or, to look at it another way, the current state of D determines the state of Q at the next sensitive clock edge (e.g. Positive edge).
All that is to say that what you assign to Q should rely on D.
Your assignments, as they are, won't do anything - you have multiple, conflicting drivers for q and q_bar. If you want to do it that way, you need to test D and use its value to determine what is assigned to q/q_bar.
input d ,clk;
output q,q_bar;
reg q,q_bar;
begin
q <= 1b'0
Q_bar <= 1'b1
q <= 1b'1
q_bar <= 1b'
end
endmodule
by Jeff Child
