I am uploading the pic of circuit without load and supply
Mark ... do you understand what Kubeek is telling you? He's pointing out that the 1 ohm sense resistor is too large and because of this the input voltage is so high that the MAX4080 with a gain of 60 is trying to put out more voltage than it can output.@Kubeek: Yes, i noticed that the output for 1 ohm resistor is getting stucked at 11.66v. but i cant use such a high voltage with microcontroller ADC, as i have to measure the current value and keep monitoring. Its like a diagnostic system.
What make and model of DMM are you using? Are you using more than one to measure both current and voltage concurrently?@BillB3857: yes it did work, but still there is some difference in reading from the actual load current value. That is + or _ 0.08A when measuring load current of 0.68A.
by Jake Hertz
by Aaron Carman
by Aaron Carman
