Clearly one of those is not true, my bet is that the resistor is not exactly 0.1ohm.Yes, current drawn by the steady light is 0.74A and the voltage accross 0.1 sense resistor is 70mv
And once again I ask, how exactly do you measure those numbers?
Like I said, connect RS+ to your supply voltage, connect RS- to a resistve divider with a potentiometer such that you can vary the voltage difference between RS+ and RS- from say 0V to 100mV. Set different points and compare the input voltage with output voltage, then you will see if the output function is linear, or there is some offset voltage, or it behaves in some other way.
