Current Requirement for Stepper Motor
learntodo
Joined Sep 9, 2015
3
I am driving a 6 Wire Stepper motor. The problem is that during running they consume heavy current, if i use low current stepper motor then I am not able to get the required torque.
Kindly guide me what should i do?
Regards
Alec_t
Joined Sep 17, 2013
15,119
The Laws of Physics are against you ;). You need to provide a power supply, and switching circuitry, which can handle the heavy current.
22,082
It is not uncommon for stepper motors to get quite warm. You don't need to worry about this, it is quite common and they are built for it. If you are worried about it you can mount the motor inside a block of aluminum with a large surface area and lots of fins. If that is not enough you can blow cold air over the fins and move the heat away from the motor.
