Sorry I guess I am not expressing myself clearly.your striking off on a tangent.
Your goal was to control current over a fixed resistor. That will generate a certain power that must be dissipated. You can choose to generate that heat in a continuous fashion, or you can pulse it in PWM fashion as twice the heat, half the time.
You've jumped back to the PWM thing when it was explained that the PWM was filtered to linearly run an amplifier.
Do you need PWM current or do you need linear current?
I don't need a particular form of current, I just need charges (Coulombs), and a specific quantity of them determined by experimental parameters. So that translates to Ampere*second. But I also need to use as little power as possible because there will be several of these reactors running 24/7 at considerable currents. It is part of the design considerations of this current regulator, so I don't deem it to be tangential.
What I was trying to get at is a point of confusion of mine. In my example, when I have a PWM signal at 50% duty, at 20V to generate an average of 1A, I consume 20*2*0.5=20Ws. But if I filter the PWM signal, then the actual voltage (not considering ripple) is going to be 10V, and will still give me the 1A, but now energy consumption becomes 10*1*1=10Ws. This does not make sense to me. How can the act of filtering have this effect on the energy consumption. So I must be thinking something in the wrong way, and that's why I am asking about it.
I hope the further explanation can illustrate what I am confused about.
(BTW, I am not passing current through a resistor, this is an electrolytic cell for organic compound degradation, so the load is purely resistive, but it is not a resistor "per se").
