How do I get create a circuit with only NOR gates?
Show us the circuit with NAND gates and explain how it was derived.How do I get create a circuit with only NOR gates using the following diagram below? I'm only able to come up with a circuit with only NAND gates, but not NOR gates
You should be telling us.would this be a correct answer? for NOR gates
NoOh, I see! These 2 inverters also have to be removed, right?
Overall, it would look something like this:
This is A correct answer, but it is not the simplest.would this be a correct answer? for NOR gates
At this time, it appears that you are throwing random gates at the problem without understanding why.View attachment 203044
Like this?
Oh, for heaven's sake!(!B+!D)(B+C) = !BC+!DB+!DC = (!B+!C)+(!B+!D)+(!C+!D) = !B+!C+!D
Try to answer the question asked and not guess what it means or the next step.(!B+!D)(B+C) = !BC+!DB+!DC = (!B+!C)+(!B+!D)+(!C+!D) = !B+!C+!D
Wrong!!X OR !Y
You omitted the last step.!X OR !Y
by Don Wilcher
by Dale Wilson
