Well, the diode is normally reverse biased, so does not conduct anything (apart from leakage current but you can probably ignore that.)just to verify, the diode on the input side of this circuit:
will drop the V 1V, so if the datasheet calls for the forward V on the 4n33 says 1.3V for its led, i should do the resistor value so that it brings the V down to 2.3 and then the diode will will drop it the other 1V? is 1V an approximate value for the 1n4004 diode or approximate because i measured the V from gnd to pin 1 w/out the diode and got 1.3V, w/ the diode it was 120mV, so it seems a bit more than 1V, but the 4n33 still worked in the fact that it triggered the input.
i just happen to have some 470 and 560Ω 1% 1/2W resistors that i think will be the perfect fit for this, w/ that close, does it matter which one i use? fwiw, they are metal film resistors if that makes any difference.
thanks in advance,
bob
by Jake Hertz
by Aaron Carman
by Duane Benson
by Aaron Carman
