Attached is a block diagram. I am required to draw the equivalent signal flow diagram however, I am not very sure of the answer I get. My signal flow graph is also attached. Kindly assist.
Is this how it should be?Your bottom most link does not terminate at a summing node.
Regards, Dana.
Hello,Attached is a block diagram. I am required to draw the equivalent signal flow diagram however, I am not very sure of the answer I get. My signal flow graph is also attached. Kindly assist.
