You don't have to physically remove the diode and resistor (though you can if you want to). It is sufficient to simply connect to the circuit in such a way that your are measuring only across the meter movement itself.oh. i see. so what is your means is take the diode and resistor firstly out so the diode and resistor don't to be measured mix with the coil resistance? wait a minute. i trying to desoldering it.
