Hello,I would not use a 20W 47 Ohm resistor to replace four 10W 10 Ohm resistors in series.
I would, however, use a 50 Watt 39 or 43 Ohm resistor if available.
Considering your below quote, i thought that the resistance between 40 to 70 Ohms is OK, so i found out that 47 Ohm 20 Watt Resistor. these Big resistors are difficult to find here. We have this Russian 10 Ohm 8 watt 1% resistor here but it is unusually big and arranging it in Series is practically impossible on the PCB board i have built.Well, I do not know what you can get. Whatever you CAN get should measure around 40 Ohms, and be rated for at least 40 Watts.
You can increase the 10-ohm resistors to 15 to 18 Ohms if you would like.
Tried... Just cannot find 40 Ohm 40 Watt Resistor.Well, I do not know what you can get. Whatever you CAN get should measure around 40 Ohms, and be rated for at least 40 Watts.
Thank you for your useful reply, but i have one question though, what possible problems am i looking at if the the Wattage of my total resistor arrangement is 20 Watts, say for example i make the arrangement as "4 x CRL-5W 10 Ом 5%" OR "2 x SQP-10W 20 Ом 5". Will the Resistors over Heat and Blow off?OK.
Get six more of the 20 Ohm 10W resistors.
Connect them together two at a time in parallel. Then connect the four groups of resistor pairs together in a series string.
Connecting two 20 Ohm 10W resistors in parallel makes a 10 Ohm 20W resistor.
Connecting four of those 10 Ohm 20W resistors in series makes a 40 Ohm 80W resistor.
Thank you for your reply,I know what the original circuit has; as you thoughtfully provided the schematic in the first post.
You can try it with the total 20W rated resistors if you wish, but they will most likely get fried (burn up), and may damage your PCB in the process.
Hello,I don't know what your chassis is made out of. If it is metal, it would help to carry away the heat. If non-metal, it would tend to thermally insulate.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Duane Benson
