I can solder, however trying to keep as simple as possible, so adding things to the board is more than I was looking for.. perhaps there is a correct item you could link to?The way I see there is only 1 option.
That is to invert the output if the 555. Then the relay will remain off and sw. on when time is set.
U need to add an additional transistor and a resistors to the PCB. It won't easy to solder if you never done SMD soldering in tight places
Or may be replace the SMD transistor with a PNP and some additional R's might do the trick.
Better yet use the Relay contacts to do what you want. Cause it has SPDT contacts you know.
N/O and N/C are there so why don't you use those.
Using the relay contacts to achieve what I want... like having the relay interrupt the current to another relay , which switches on at power up... and off when 'interrupted'... I considered this, but then I would need a power supply to power the thing, and another to power the second relay... is this what you were talking about?
