Yes, take a look at the data sheet. Note pins 1 and 15. Less a path to ground through those two shunt resistors there would be no outputs.Also do I need the 0.5 ohm resistors ?
Yes, resistors of zero ohmsYes, take a look at the data sheet. Note pins 1 and 15. Less a path to ground through those two shunt resistors there would be no outputs.
@albert, will it work less the resistors? Less the resistors we would ground pins 1 & 15 correct? I agree they are only current shunts but we would ground those pins.
Ron
A "little hot" or a blister on your finger after a half second to a second (on the plastic body).thanks a lot; it works.
I noticed the L298N gets hot a little bit;
Is the device reliable if I keep it running for a very long time ?
If you can keep your finger on it then it doesn't need a heatsink.Do you have it mounted on a heat sink?
