I am creating a LAN with a Dev server running Ubuntu. I need to have a statis IP for dev box so that developers can use SSH to access the server remotely. Since the internet connection with static IP is expensive, I am planning to take two connections from the ISP, one with static IP for the server and the other for LAN. I plan to connect the dynamic IP internet to LAN using a switch to which the server will also be connected. THen I plan to install another netowrk card on the server to connect the static IP internet. Will this cause any problem since the server will effectively be connected to 2 networks. Also, will it be possible to use SSH remotely? Are any special settings required for this to work?
Thanks,
Sachin
Thanks,
Sachin
