Hi, I have two separate devices talking to each other by using asynchronous serial communication. Each separate device has their own separate ground plane. Device A has a very noisy ground plane. When I connect the two ground planes in order to implement the serial communication, device A introduces a lot of noise in the ground plane of device B making it malfunction. I need to find an SMD component to filter out the noise from the ground in device A to the ground in device B. I tried a 10uH inductor, but that didn't do anything to help. Using a 10k resistor helps a little bit, but the noise is still there. Can you please give me a component name that I could use here? Thanks.
