Connect PCB ground to Metal enclosure?
ke5nnt
Joined Mar 1, 2009
384
If I have a microcontroller circuit mounted inside a metal enclosure powered off a 12V DC PSU, is it good practice or recommended to connect the PCB ground to the enclosure?
LDC3
Joined Apr 27, 2013
924
Connect the ground wire from the AC connection, I wouldn't bother with the ground from the 5V circuit. Since the idea of connecting a ground to the chassis is to reduce shocks from high voltage wiring, then there is no need to connect a ground from 5V circuits. There also might be feedback that can cause strange behaviour.
