That .! my friend is the 64 million dollar question.
ha ha ha did you missspell is it mill tril
no, that's a momentary toggle switch. my old button broke so i just put a new switch on to replace the button
like one of these but a momentary version so it pulls back down when you release
yeah im using it to turn it on. i just kinda flick it up and it starts and the switch falls pulls itself right back down. essentially the same as pushing a buttonDon't tell me you are using it to switch on your system.',',',',',','
Awesome. Push buttons are over rated. Toggle switches is where its at!no, that's a momentary toggle switch. my old button broke so i just put a new switch on to replace the button
Looks like one of my kludges.
I've been running a BBS / print server for around 20 years, using a really old computer, the kind with a push on / push off power button. I also use it as a file server, it is handy for backups. The only reason I suggested a relay way back when is you don't want to inject voltages into an unknown circuit like the motherboard switch, and both MOSFETs and transistors must be biased correctly. With a relay, it doesn't matter, and relays can be very small indeed.
I gather you have your own vision what you want. I'll respect that. If you want any more input from me just PM me.
A toggle switch. seems to be a relay at the first glance.no, that's a momentary toggle switch. my old button broke so i just put a new switch on to replace the button
