Note: In the future I'll use blue text when referring to the light bar circuit (circuit 3) and red text when referring to the Red-Yellow LED circuit (circuit 2).
I just threw this together as a theoretical design in the works for a light bar circuit I want to build later. This light bar circuit is meant to be activated via switch and should illuminate up to 10 LEDs indicating different charge statuses of a 12v battery (subject to charging) not under load. I know I'm getting a little ahead of myself here as I'm not even finished working on the Red-Yellow LED circuit, but if you don't mind I figured I'd work on the two simultaneously. Anyway, the following is my initial design (which probably would not work, but it gives me somewhere to start):
The resistor values are not correct because they are based on a rail voltage of 18 volts, which I don't believe would be sufficient to power all of the LEDs simultaneously. I believe new resistor values would have to be calculated and potentiometers would need to be used to get specific (non-standard) resistances.
With respect to the Red-Yellow LED circuit we've been talking about since the beginning: The only reason I'm hesitant to just build your design and call it good is because I don't fully understand it yet. Having a full understanding of the circuit and how everything works in the circuit is every bit as essential to me as having a finished product that works.
Over the next few days I'd like to develop a clearer understand of how your circuit design works, as it is better and should function properly under more conditions.
