Fine. You get a break, and I get stuff that works.Oh give me a break.
I attempted to do something like this with a heat gun. Ended up frying the board pretty bad (Probably my lack of patience). I will have to try this. Anyone else have good part salvaging techniques? Solder pump and wick is a painfully slow process for me. The pump keeps getting jammed too..I find it fun to salvage parts off of boards. For boards with through hole components, I go outside, prop the board upside down on something that keeps it off the table surface.
I then take my mini butane torch and make a quick pass over a few components at a time, and when I see a solder puddle, I give it a quick blast of air with my air hose. Once the melted solder is blown away the components usually fall to the table surface below.
Just make sure there is nothing or anyone standing in the direction of the air hose that you don't want solder being splattered on. That's one reason I do it outside, as well as for fumes. Takes no time to get parts off boards that way.
Thread starter | Similar threads | Forum | Replies | Date |
L | Collecting registers into memory/FIFO | Digital Design | 16 | |
W | Single shot with oscilloscope - when stop collecting data | Test & Measurement | 3 | |
M | collecting the ADC value | Programming & Languages | 1 | |
M | ADC collecting the ADC value from the AN channel. | Microcontrollers | 9 | |
Collecting parts, page 2 | General Electronics Chat | 4 |
