coding porblem~~~~~~~
Jackerq1
Joined Nov 1, 2011
4
i use MBLAB PIC 16f628A
here the coding below ~~~~~~~~~~~~~~~
i wan work as normal traffic light , then my coding all can work but why the else if (RA2) cannot work ? is that i set the I\O pin wrondly ?
#include<pic.h>
__CONFIG(0x3F38);
unsigned long int i;
delay1s()
for(i=0;i<30000;i++)
NOP();
void main()
CMCON=7;
TRISA=0x00001111;
TRISB=0b00000000;
PORTB=0b00000000;
PORTA=0b00000000;
while(RA0)
while(1)
if(RA1)
PORTB=0b01001011;
delay1s();
delay1s();
delay1s();
PORTB=0b10100001;
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
goto s3;
else if(RA2)
PORTA=0b00001000;
delay1s();
PORTA=0b00000000;
delay1s();
break;
s0:
PORTB=0b01001100;
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
goto s1;
s1:
PORTB=0b01001011;
delay1s();
delay1s();
delay1s();
goto s2;
s2:
PORTB=0b01100001;
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
delay1s();
goto s3;
s3:
PORTB=0b01011001;
delay1s();
delay1s();
delay1s();
SgtWookie
Joined Jul 17, 2007
22,230
I am simply re-indenting your code and using the CODE tags to preserve your formatting.
Rich (BB code):
#include<pic.h>
__CONFIG(0x3F38);
delay1s()
		NOP();
void main()
	CMCON=7;
	TRISA=0x00001111;
	TRISB=0b00000000;
	PORTB=0b00000000;
	PORTA=0b00000000;
	while(RA0)
		while(1)
			if(RA1)
				PORTB=0b01001011;
				delay1s();
				delay1s();
				delay1s();
				PORTB=0b10100001;
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				delay1s();
				goto s3;
			else if(RA2)
				PORTA=0b00001000;
				delay1s();
				PORTA=0b00000000;
				delay1s();
				break;
s0:
			PORTB=0b01001100;
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			goto s1;
s1:
			PORTB=0b01001011;
			delay1s();
			delay1s();
			delay1s();
			goto s2;
s2:
			PORTB=0b01100001;
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			delay1s();
			goto s3;
s3:
			PORTB=0b01011001;
			delay1s();
			delay1s();
			delay1s();
Rich (BB code):
void main()
    CMCON=7;
    TRISA=0x00001111; //should this not be 0b00001111?
    TRISB=0b00000000;
    PORTB=0b00000000;
    PORTA=0b00000000;
*SNIP*
