- Joined Jan 23, 2018
- 18,585
That will allow decoding the unlock command after the call gets answered and prevent incorrect unlocking. all that the system needs then is a phone line interface and a power supply.
This seems like the solution, but as some have pointed out BEWARE of scam calls, so i'll have to stick with more technical solutions.Use 2 of these (https://www.vikingelectronics.com/product_docs/DOD/406.pdf) in parallel.
Use terminals 6 and 7 of First to trigger your system
Connect 6 and 7 of the second to the telephone Lines.
When the Ist Ring is received, both the relays operate, 1 triggers your system, the second extends a loop to the exchange to trip further rings.
This will activate the relay after a single digit is pressed, (that what i understood, that it doesn't activate after multiple digits are pressed,, it uses just a single digit). Hence making it easy for anybody that knows the phone number to guess the digit.
What's a UP?Alternative is to use a UP to detect ring and decode tone(s).
These 2 seem like the most correct solution, but I have zero knowledge with arduino.Here is another possibility - http://www.cermetek.com/catalog/telephone-line-interface/datasheet/xe0068dtrevc.pdf
https://www.futurlec.com/Mini_MT8870.shtml
Regards, Dana.
Can you please link to oneThere are also all kinds of multiple number circuits that need more than one number to trigger them. That could make it very secure because it would be simple to have it hang up if the wrong number were entered.
by Jake Hertz
by Aaron Carman
by Duane Benson
by Don Wilcher
