Aside from understanding the title, I'm having trouble getting this relay to open up by itself. Honestly I don't see how it's going to do that.
Below is a drawing of the pinouts and as best as I can tell how the relay is wired. I can clearly identify the route of the Capacitor and the Resistor to the pins, but I can't be sure about the coils. I see two wires twisted about at every terminal. Is there four coils in there? And I've tested the pins with 12 volts. The pins, I've numbered them for reference (actual pin count may differ). When I strike pins 1 & 4 with 12 VDC the relay energizes and kicks in like it should. When I apply 12 VDC positive to pin 2 and negative to pin 6 the relay energizes. In both cases I've left the relay energized for one minute. That's GOT to be long enough for it to open the circuit. But in neither case does the relay ever open. I've even jumpered pins 1&2 and 4&6. With those pins jumpered the relay still clicks in and never opens. When I jumper pins 1&4 and 2&6 the relay does nothing.
This thread is being opened because another thread was asking about relays and I happened to mention I have a delay opening relay. I've never figured out how it works. It comes off of a 1987 Toyota Celica (wife wrecked it). The cost to replace is at AutoZone about $45.00. Just wondering how to make this work and what to expect of it. I'm actually waiting on parts for another project. Meanwhile I'm just tinkering about with silly stuff.
[edit] When I energize 2&6 the relay closes softly. But when I energize 1&4 the relay clicks in with more force. And I've tried to energize the relay by various combinations of 1&6 and 2&4. No matter what - - - .
