THIS thread was discussing how to identify which circuit breaker is associated with which outlets and other stuff. I made a comment that kind of took that thread off topic, and somewhat hijacked. I don't want to hijack anyone's thread so since the conversation seems to want to continue in an "off topic" direction I'm opening this thread for anyone who wants to discuss this further. Personally, I don't have a problem that needs resolving. However, I'm always open to hearing what others have to say about the matter.
So here's the outlay:
I've signed the contract with a contractor to put a second story on my garage. At present (work hasn't begun yet) the garage is powered by two breakers. One 20A 120V circuit and one 30A 240V circuit. When I run too much equipment on the 20A circuit, i.e. saw and vac, I sometimes blow the breaker. So I've been running the vac on half of the 240V circuit. I know I'm going to hear it for that. But all that is going away.
The addition is above the garage and I'm purchasing a table saw for 240VAC and the rest of the equipment will be 120VAC. Drill press, band saw, chop saw, planer - etc. etc. Currently the power coming from the pole goes directly over my back yard. I've always hated that intensely. Internet and phone line also crosses over the middle of the yard. What I want is to run power to the back side of the garage. But putting a disconnect on the back side will be difficult for the fire department to find in an emergency; so I want the meter and disconnect on the front of the garage. The power can come in through a conduit from the back of the garage to the front then down to the meter and disconnect where it can be immediately seen and shut off in an emergency. The electrician said he wants to break up my new driveway and run power lines from the garage to the house. I'd rather not. So I've asked him to put another overhead line from the front of the garage to the back of the house. He didn't seem to balk at that idea, but I have yet to finalize the plans with him. I just don't want to break up new concrete (5 years old). But if I must I will. I'm also planning on an additional grounding rod. I've been having trouble with the GFCI on the jetted tub. It doesn't always break when I push the test button. I've replaced the GFCI's but get the same results. So an additional ground rod should improve matters. But I'm not the expert on this subject. So discussion is welcome.
This is what I'm thinking
