Hi, I need modification of cheap Christmas garland lights for my diorama
it is going to be battery operated (2x CR2032 6v in series or even 1 battery if possible 3v) an I will use only four 3mm led, i need ic yt803a for different programs (it has 8 modes)
This schematic of circuit is originally 220v ac powered. Which modification of circuit do I need for it to be operational for my diorama (probably modification of resistors and diode); I need minimum number of parts because the circuit is battery operated.
Enclosed images show versions with 2 and 3 transistors but circuit is the same.
Thank you in advance!
Cheers!
Cheers!
