I am looking to do a small project that is similar to generating electricity using a wind turbine. From my research I have found that most modern large scale wind turbines use permanent magnet synchronous generators, which seem to be relatively high cost. I am trying to understand if a BLDC motor would be the best option for generation in this project
The project would differ in a few key ways from modern wind turbines:
1.) Size - anticipated power needs between 500 W and 1,000 W
2.) RPM - rpm will likely be higher due to increased air speed (~ 100 MPH)
3.) Power output - consumed locally by DC equipment.
I am looking to maximize efficiency and at lowest cost. Any input or suggestions would be greatly appreciated
