I am trying to create a steady DC output to drive some pHEMTS, HMC7357. To control the gates I need to produce -1.4, and -0.8V and supply about 0.5-1 mA. To do so, I was planning on using a filtered PWM output from a microcontroller, followed by a -1 inverting op-amp circuit. I was playing around in LT-spice and i got some results I didn't expect. Perhaps someone can help me understand what is happening and why.
Above is a screen capture of my schematic and simple transient analysis. I am using a op-amp model from the TI website for the LM358. The input is a 500 Hz 50% duty cycle square wave with a magnitude of 5V. I am not plotting the input on the graph because the X axis time scale is long. The circuit acts as one expects, the PWM signal is filtered at each stage, V1,V2 and the output, Vout, is a steady -2.5V.
However, when i change the value of the feedback resistors, now 1K instead of 1 Meg, the value of the output changes drastically. From what I understand about IDEAL op-amps it shouldn't really matter what value of feedback resistors I use? clearly I am missing something fundamental to op-amps.
BONUS question: I tested the first circuit, with 1Meg feedback, on a breadboard. Without the pHEMT connected, I got the -1.4 and -0.8V as simulated and expected. Connecting the circuit to the pHEMT's gate:
With no driving power to the pHEMT, meaning virtually no current DC to the gate, the outputs work as expected.
When I apply a RF power, ~20 dBm causing at most 1mA gate current, the PWM output from the AVG drops, subsequently dropping both of my voltages, expected -0.8V to -0.7V and -1.4 to -1.3! None of my circuit elements should be drawing much, if ANY current, does anyone have any clues?
Happy to provide and more context,
Thanks for any and all help,
Sami
Sami
