Charge Pump
falconite
Joined Nov 6, 2010
23
Hello everyone,got another question.
Do SCRs work for low voltages in the range of 2-20 V???
Actually once i get to charge up all my capacitors to the required voltages, i need to connect them one at a time to another capacitor C_L.
To put it more clearly, say from t=o to t=t1, C1 should be connected to C_L.
From t=t1 to t=2*t1, C2 should be connected to C_L, and so on.
If i use SCR s as switches(one for each of the 10 capacitors) and connect the other end of the SCRs to C_L, i can turn each one on and off in a sequence.
The problem is will the SCR work for such low voltages???
Bernard
Joined Aug 7, 2008
5,784
The conducting V of a 2N5061 is about 1/2 to 3/4 V @ dropout I of 5mA. Trigger of less than 1V. Might consider small reed relays. Are you still limited to 2 V for all control ckts?
falconite
Joined Nov 6, 2010
23
Actually I'll use a boost converter to boost up the voltage to around 20-22 V.
I can use this voltage for switching purpose (cant I???)
