Got my alternate speedometer today. Its not the same but pretty much the same pieces slightly rearranged.
My thought is that the speedometer and odometer are no more than a voltage meter essentially calibrated with MPH/volt. So If I remove the speedometer portion I will be able to calibrate the voltage output vs frequency input. Then I will be able to just play with the circuit board until I am successfully able to change components in a way that will effect the voltage output vs frequency input.
