Center-tapped Transformer
worldHello
Joined Oct 15, 2014
23
So I need a transformer that has a center tap at the primary (not the secondary). Most transformers I found have center tap at the secondary.
This is my strategy:
Get two transformers and line them together. The middle is then the center tap.
Does this strategy work?
#12
Yes. Just be sure to check the phase relationships of your secondaries so they add up instead of cancel each other.
alfacliff
Joined Dec 13, 2013
2,458
there are a whole bunch of transformers with center tapped primaries, called control transformers. used in industrial equipment to supply control voltage, and have either a center tapped primary or two primaries for a wider range of line voltages.
38,521
I'm confused. :confused: Initially you said you want to make a transformer with a center-tapped primary and then you say you have a whole bunch of such transformers. So what do you want?
atferrari
Joined Jan 6, 2004
5,012
Are they kind of autotransformers implemented on the primary? Isn't it easier to have that tap in the secondary?
Sorry. I cannot grasp the concept.
djsfantasi
Joined Apr 11, 2010
9,237
The OP stated he needed one transformer with a center-tapped primary .
Alfacliff said there was a whole bunch of such transformers.
I think you mixed up the posts from two members.
