Sometimes, when a wobbly charger is plugged in a socket, it takes some iterations to ensure a proper 'contact' between the charger Pin and Socket, for charging to start.
So what exactly is a 'contact' between the two surfaces.
To what extent are the two metal surfaces touching each other? Are the two surfaces touching each other at atomic levels? Are the surface atoms of charger pin enmeshed with the surface atoms of the socket pins? At even more micro level, does the flow of electrons takes place thru a continuous bridge between the socket pins and charger pin or at some point there is actually an induction of energy where power just leaps frog into space and enters the charger pin like it happens in case of a transformer (primary to secondary jump).
Thanks in adv and regards,
Rahul
Rahul
