How do you define "condition of capacitors"? Filter capacitors, tuning capacitors, coupling capacitors, timing capacitors?
How can I do that?The same degree of measurement may be made with a voltmeter set to AC volts..
S | Troubleshooting Capacitors on PCB | Technical Repair | 1 | |
E | Input de-coupling capacitors | Power Electronics | 10 | |
S | Problem with Type X and Y Capacitors | Power Electronics | 3 | |
E | AC induction motor capacitors | Technical Repair | 7 | |
S | Capacitors on HV pcb Oscilloscope Tektronix | Test & Measurement | 2 |
