Hello, I'm designing a PCB for a capacitive touch sensing keypad using eagle. The sensor I'm using is Atmel's AT42QT1110-AU IC.
I've read a number of guides on designing capacitive touch sensors and I'm aware that component placement, trace length and routing are all important in creating a reliable "Product".
My questions: Are the components too close? With the traces so close together will the capacitive loading reduce the sensitivity too much? Are the signal traces too close to the sense traces?
Unfortunately I'm using a single layer board.
I wasn't sure how to add pictures in text (without link) but schematic and board (as .zip) are attached.
Also, the electrodes are 8 mm across although they appear larger with whatever layer settings are on (I'm new to eagle) and they will have a small hole drilled in the center for led back-lighting.
Touch sensor Datasheet: http://www.atmel.com/Images/Atmel-9520-AT42-QTouch-BSW-AT42QT1110_Datasheet.pdf
Design guidelineshttp://www.atmel.com/Images/doc10752.pdf
Any suggestions on component placement/trace routing (ect.) would be greatly appreciated!
Thanks!
(this is my first post so hopefully this is in the right place)
Thanks!
